rudder surface MV Gofret I
After months of sailing and manoever on trials with the Gofret I have the impression that the rudder surface of the vessel is not in accordance with a vessel in real of this size.
I tried to reach several times with different rpm and rudder deflections but it is impossible to reach a higher rate of turn then 15 degrees without running out of his PIVOTpoint wich is passing the bow repeatly .
My question : can you check this out because to maneuver with this vessel in a normal way is disappointing.
